Mount sd card on HTC Aria
hey i had created 2nd partition using ROM manager and i completed my process but my 2nd partition is unmounted i cant find it anywhere... can i mount it by anyway... if not can i at least delete it... pls help me
I used paragon partition yesterday. It was free and very simple. I Google and found a free dld and it worked with my micro SD in an adapterthat was plugged in to a external usb hub.
Hope i helped.y
Hope i helped.y
yes i do knw of paragon partition... but i dont think so it will display my 2nd partition because it is not mounted... paragon partition and minitool is kind of same thing... so even in minitool my 2nd partition wasnt displayed
