Help Mount storage to pc
Pho3niX90
Hey guys,
2 days ago i accidentaly deleted very important pictures on my iconia, so i want to do a data recovery, but before i can do that i need to be able to see my storage on my computer, it must show as a flash drive for example, but i am struggling to do this, is there a way to do this?
Have you downloaded the USB driver from Acer yet.This will get you started if not...
Download
The device auto installed drivers. I am able to pickup the device on the computer, but registers as iconia a500, but i need it to display as removable storage device with a drive letter. I have however downloaded the drivers and they dont install because its allready instaled, tried uninstalling but windows auto installs drivers, and manualy also doesnt work because it says drivers are older than the ones installed.
Usings windows 7 sp1
Does anybody know how to do this? Or atleast what software can restore deleted files on a portable device? Have tried Recuva and getdata but can't pick it up via those programs.
You can recover your accidentally deleted pictures from iconia, you just need a third party efficient data recovery software. go for Kernel for FAT and NTFS windows data recovery software for the recovery of your data and files from it. for more details for to Windows Data Recovery - NTFS data recovery - Partition Recovery - Recover Deleted files
Thanks for the advice, but, that software doesn't support MTP devices? with other words, only supports device, drives with a drive letter (MSC).
