MolecularSpade
Member
Im on 4EXT recovery, how do i do this?
and should i partition EXT3 or EXT4?
4 is the best. Have a look through all teh menus on 4EXT. The option is there
Best bet is to mount SDcard in recovery but NOT connect USB. Wait for when the langauge / keyboard settings are on screen for gparted.... Then plug in USB.
Ok so im on Gparted with my phone plugged in. In the top right corner in the drop down menu it only says /dev/sda (512.00 MiB) Im guessing this isnt right?
