Don't quite follow you.
Mounting the card means just that. You must unmount the card before removing (or turn off power), and click "mount" after you put it back in (unless you installed it while powered down).
You can move some apps there using an app2as app. And your PC or esfilemanager app or Astro to move music and pictures.
(even though your phone has plenty internal to not worry about running out of space. I havn't moved any of my 200 or so apps to the card. They pull up faster from where they're at. I send my pictures to a cloud, and my music is kind of scattered between in and ex. 200 songs is so small I havn't decided where I want it. It isn't hurting anything where its at).
