Hi im Albert...I have a problem with my samsung galaxy s2..after rooting my phone now i can not move any app to the sd card....is there any app that can can help me to solve the problem....thanks
Hello Albert! Welcome to the forums!
After rooting you may be able to partition your sd card and have DarkTremors a2sd move them automatically but not sure on your device.
Which carrier do you have? There are a few forums for the S2 you can find them here and perhaps locate the answer there: http://androidforums.com/android-phones/
Otherwise there are some apps in the play store such as Link2sd that may work.
I'm not sure if there is an option on the device itself to move the app to sd...if there is, it may not move the entire app, only part of it.
Check out your device forum for more info on that k?
