W wadboram Newbie Jan 13, 2011 #1 I have used App 2 SD and it works fine, but it some apps are not movable. Any other way to free my internal memory and move apps into SD ??
amlothi Android Expert Jan 13, 2011 #2 You have no idea how many millions of threads there are on this subject already. Here's a few... http://androidforums.com/desire-tip...apps-sd-card-unrooted-device-noobs-guide.html http://androidforums.com/htc-desire/150516-low-memory-notification-despite-moving-all-apps-sd.html http://androidforums.com/droid-support-troubleshooting/237205-low-memory-issues.html http://androidforums.com/htc-wildfire/160499-using-sd-card-memory-instead-phone.html http://androidforums.com/desire-tips-tricks/160560-force-apps-install-sd-without-root.html http://androidforums.com/htc-wildfire/160499-using-sd-card-memory-instead-phone.html http://androidforums.com/motorola-droid/169421-apps-sd-card.html
Slug Check six! VIP Member Jan 13, 2011 #3 Apps are only able to be moved to external memory if the developer allows it. System apps are also unable to be moved to external memory.
T takeshi Android Expert Jan 13, 2011 #4 ...and you don't want to move widgets or anything needed at startup (or while the SD card is mounted).
