Help Move Files to SD Card
IPW
Hi folks,
I posted this on the wrong forum and made litle progress!! My Fault.
I am 2 weeks into my starter Android and am still struggling a bit.
Can someone please tell me how to move Voice Recorder Files to the SD card?
In fact, it would be helpful if I knew how any file could be so moved.
Thank you.
Ian
Settings->Applications->Manage-> SELECT APP, move to sd button. You could also try app2sd from play store. But Im not sure how well this program works, and i have no first hand knowledge.
Root access and TIBU(titanium Backup), or antek app manager would work also.
If I helped hit the thanks button.
Thank you. Sadly, when I get to the 'Move to SD card' button it is not backlit and thus not active.
I will try and download one of those tools you suggest.
Stranger and stranger....
I downloaded and installed App2sd. Unfortunately, Voice Recorder is not an application that can be moved to the card!
Any other ideas about how I can get to those Voice Recorder files?
Thank you.
Ian
root your phone
download Link2SD from play store
follow the instructions
PS: It is not advisable to move system apps to SD card
Thank you Sasuketobi. I fear I have to admit again that I am only 2 weeks into Android use and thus have not a clue what you mean by 'root your phone'.
I note your warning about moving Apps.
Ian
With Titanium backup you can make system app to user app and then move them to the sd. I did it with maps as they were integrated into the rom and could not be moved to sd.
