Move more then 1 at a time
D
Deleted User
Guest
I will admit the drag n drop feature is nice on the Tab, but it sucks that it only lets you drag n drop one file at a time. Is there anything that can help make this better or do I have to wait for an update in firmware or android 2.3 or?
Sorry, I'm confused in what area you are talking about.
Drag & Drop what and using what?
The file folder on the galaxy Tab if you long press a file it lets out drag it into another folder.
I suppose I am just use to my vibrant in this perspective.
Cutting & Pasting works on the same principle as Move.
Using Astro all I do is first select the Multi icon, then I select all the files I wish to move then I Edit and select Cut.
This then brings up a Paste icon.
Final step is to then navigate to where you want the selected files to be placed and hit the Paste icon.
Job done...
