Help Move shortcuts from "Applications" to "Home"
morrisg
It's beaten me!
From one of the 7 "Application" pages, I want to move a shortcut to the "Home" page.
I have done it once, but can't remember how I did it.
I can move one from the 'lower' section of the Home page to the 'upper' section, but not 'across'
Can someone save my sanity.
Using Android 2.3
Thanks
Morris
It's beaten me!
Using Android 2.3
Thanks
Morris
dont you just long press the app and drag it?? 0_o
Nearly there.
I had a 'blank' spot on the Home Screen so I managed to 'long hold' and drag a shortcut from Apps page1.
I can drag a shortcut from Home Screen1 to Home screen2, but can I drag it to Apps page 1 or 2 etc?
Thanks for the quick response.
Morris
Or you could use another launcher, (launcher pro / open home / adw launcher) and hide apps from your draw, and sort by alphabet or whatever. Generally, just long press on your home screen to create your shortcut.
