I am new to android. My internal phone memory is almost full, but I have a 16 gig SD card. Is there a way I can save all my apps to my sd card and start downloading the other apps i get straight to my sd card?
until HTC and TMO push out the update to FroYo (Android 2.2) the only way you can do what you are wanting is to root your phone and install either a custom version of 2.1 that has A2SD (apps to sd) or one of the custom ports of 2.2 which has native A2SD.
if you choose to do this I must warn you that rooting your phone does void your warranty... how ever if you still want to, check out xda-developers under the section for the HTC Espresso/MyTouch 3G Slide.
I would have posted a direct link but that would be a violation of androidforums.com rules
