Moving cursor left/right when writing SMS
Hawker
Android Expert
Are there any keys you can press to do this?
If I tap to the place I want to go, 9 times out of 10 its 1 or 2 characters out, and the only way to then move the cursor is to drag the blue marker. I find this extremely annoying and awkward.
It would be so much nicer to just be able to move the cursor via a key press. Is there any way to do this?
thanks
if ur using swype (i noticed u created another thread about swype, right) swipe the swype key to the SYM key.. and u'll see the buttons ur looking for. not sure if this is as easy as u'd like but its alright
Thank you very much Hashanj! This is a great tip!! Any other magic swipes like this?
ur welcome :) yup there are a bunch but looks like someone already beat me to the link :D swype is awesome, completely changed the way i type on smartphoens. if u havent already, capitalization and double tap correction are the most useful tips on that link :)
