Help Moving pictures between folders?
mattdanielc
Hi guys
I have some folders pre set up on my sd card with pictures in (e.g. different holidays) but since using the SGS2 I now have a load of pictures within 'Camera' in the Gallery - but I want to move the pictures to other folders I have set up within the Gallery.
I can't figure out how to do this - is it possible without using Kies?
Hi guys
Sure it is, a full guide on moving files can be found here, just tailor it to your needs.
Don't suppose you know how to clear the Clipboard as well do you? I copied something - but can't see how to clear it (or even access it) now?
Thanks again :)
hmm.. not sure why u would need to clear ur clipboard.. just leave it :D
and to paste, when ur in a text editor, u should see the blue tab (if u dont, tap the cursor) tap the blue tab and u'll get text options.. select/cut/copy/paste
Well...unfortunately it was a picture of my girlfriend (let's just say I wouldn't want anyone else to see them :) ) so I didn't want to accidentally paste it somewhere without knowing.
Plus I thought it might slow the phone down constantly having it on the clipboard?
It won't make a noticeable difference. Was it in the clip board as was it just being moved? if it was clipboard just replace it with some random text you randy devil ;-)
nah, its kinda like the windows clipboard (not sure how u clear that either) lol. i dont think it'll slow it down.. just copy some text from a text msg ur typing etc.. assuming ur typing something appropriate :D lol
Thanks guys - glad to know it won't slow it down. Just copied some text instead :)
(although maybe it gets wiped when phone goes off?)
