MP3 Playing
RoyC
I use the 'standard' issue MUSIC program that came with my Desire to play MP3 podcasts that I download daily.
I use PODKAST to get hold of the podcasts and I check they are all in the relevant folder on my SD card using ASTRO.
The MUSIC program appears to pick up all the files in the folder once directed to that folder and it plays them correctly BUT
If , say, I have replayed 2 of the 3 files in the folder and then download one or two more, the Music player only recognises the original 3 files so when it gets to the end of the third file it stops although there are two more files to play. Even if I direct it off to the same folder it only 'sees' the original three.
What do I have to do to encourage it to pick up all the files in that folder and to update its playlist?
Roy
