Help MS voice command equivalent with Epic?
sidwin
I love voice command that came with MS and I'm glad to finally get an epic. I figured out how to get my incoming caller id announced. How do i get my Txt messages read outloud?
Is there anyway i can dedicate a button to use Voice command that way i don't have it navigate through the screen?
Thanks,
Sid
i have the hero... but I think it should work for you.
look at 2 apps.... Vlingo or the new Google search with active voice.
I like vlingo.
on my hero...
you can long press the search button and it will let you activate alternate searches. One of them should be Vlingo. You can also check to make it your default action.
I like vlingo.
on my hero...
vlingo is pretty awesome. exactly what i was looking for!!! too bad epic doesn't have 2.2 yet so i can't use bt over for voice dialing...
