crutchcorn
Android Expert
CM11
http://androidforums.com/index.php?posts/6828481 (I know this does not mention 323, but it works)Instructions:
Download zip to your sdcard
Reboot to Recovery
Great time to make a backup so DO IT
Wipe Dalvik cache
Wipe data & cache
Flash the ROM
Flash Gapps (http://forum.xda-developers.com/showthread.php?t=2397942)
Wipe Dalvik cache again
Wipe data & cache again
Bugs:
No Back Camera
Fixes:
Buttons - http://androidforums.com/index.php?posts/6787223
CM12
http://androidforums.com/index.php?posts/6843346 (I know this does not mention 323, but it works)Instructions:
Reboot to Recovery
Wipe Dalvik cache
Wipe data & cache
Flash the ROM
Flash SU (http://bit.ly/16hXY5J Optional; superuser settings in dev settings)
Flash Gapps (http://goo.gl/YqxI52)
Bugs:
No Back Camera
Fixes:
Data - Download the SH File: http://d-h.st/dPZk. Then, put it in /system/ and download SManager. find the file in /system/ and tap on it. Then, click su and net, then disable WiFi and click run. It should work. If you get the error IP address isn't valid, then just choose su instead of both su and net.
Buttons - http://androidforums.com/index.php?posts/6820207
PLEASE DO NOT POST DEVELOPMENT THINGS HERE
This is only to keep the forum organized and one place to keep all the rapid development changes for these two roms in one place. If you need help, you may post it here, however I'd like to keep the development talk where it is not to disrupt the forum threads.
Credits
- MikeHoncho
- Chevanlol360
- VM03
- sammyz
- LoneStar
- junkie2100
- PlayfulGod
- antonioblee1
- DMedina559
- bzo22
- DevMyAndroid
- Orionhilles
- Maslovicz
- xRaZeR_FuZioNx
- And More (you can tell me if I've forgotten, sorry)
