Root {MS323} CM11 & 12 Compiled Info & Help
Status
Not open for further replies.
Okay well I didn't ask to use it as your DD I just need to see if you can get it to boot cause if you can and me and crutch can't the FC's could be pinpointed
From the thread. You need to have stock for it to work. No custom roms over it. Or else it will fail.
From the thread:
Requirements:
You must have a MS323 running Software Version 10B.
Installation:
Download zip to your sdcard
Reboot to Recovery
Great time to make a backup so DO IT
Install the ROM
Wipe Dalvik cache
Wipe data & cache *Required*
Reboot
You're not supposed to wipe /system either.
Not exactly..... got it to work by removing 'getprop=...' Lines in the META- folder of simpliXL3.0.zip and edit the build prop in your phones system, every line with 10c, v10c or MS32310c.14#####, needs to be changed. I just extracted simplicity'sbuild.prop, and pasted into /system right before I booted into recovery.
hmm, interesting. but I see why it fails to install. try it with stock. and pretty sure it will 100% flash.
I got it to flash it just won't boot that's what I'm trying to say here simplicity was the first ROM I tried after downgrading to 10b.
That's why. The Build.prop is the problem. It will not work with any custom rom. If it does flash. It will 100% get into a bootloop/crashes. You need stock for it to boot.
You don't know how important a build.prop is, editing it would cause life or death of any phone.
I just told you I tried from stock lmao
Not fix it just get to the bottom of it to find help find a fix .....who knows if vmo3 would have gotten a ms323 that fc's like the others understand what I'm trying to get at?
True, True. I'll think about it. The problem with flashing Simplicity is that I need to relock the bootloader and then flash stock then reroot, then re-unlock the bootloader. Get where I'm at? I simply don't have the time to that kind of stuff. I barley had time to be online sometimes.
Status
