Root {MS323} CM11 & 12 Compiled Info & Help
Status
Not open for further replies.
I don't know if im stupid or something but i can't pull CWMR up with the keybind; (then again, my vibration cue comes up before the logo dims, not after.)
Update: Restored the old LAF, flashing back to stock again with the proper KDZ file.
You can't use a key bind as there is none for standard recovery, except for firmware A users. The only way to use a "key bind" on firmware B would be to flash the recovery over the LAF partition, then plug in your phone and hold power and Volume Up until you are in recovery.
Every time I try to download net.sh from dev-host, it downloads the website's HTML code. Can some one post a mirror for the script?
Trying to find the info on that; I know I'll lose fastboot access though.
Or not.... my phone wont boot. So i did a factory reset, and it still is showing cm12 boot ani. Its been 10 minutes. I looked in the zip and its pac roms kernel. I hope it wasnt the kernel from pac kk, because im on lp... :(
Did you delete data and data/media before hand?
@DevMyAndroid that guy sent you my flashable zip for pac-rom, most probably. At least that what I'm seeing here :D
People, do not, I repeat DO NOT flash internal memory disabler for pac-rom on cm! It has different kernel and framework and is not cross-compatible with cm. It will most probably cause bootloop and you'll have to reflash rom to fix that.
Oh yeah, forgot you made that. [emoji14] Yeah, no but really guys. I could make one for CM or something if you want.
Status
