xRaZeR_FuZioNx
Wait! On SlimLP, SELinux is Disabled. On CM-based ROM's, it's enabled. Can this be the reason?
What is the difference between emergency_cs and emergency?Don't forget emergency_cs please! I know I'm boring you but still![]()
Everytime I flash PacLP it's disabled. I've tried enabled roms as well. It's not the reasonWait! On SlimLP, SELinux is Disabled. On CM-based ROM's, it's enabled. Can this be the reason?
Currently I don't have thinks about what see more... In logcat we see problem with opening keymaster files, but no details why.cs restores everything, even if partitions are changed (in size) they will be restored to stock.What is the difference between emergency_cs and emergency?
I wondered the same! It's happened before but it makes no sense... I saw we make a test to see where in the world people have working/not MS323sI personally have no more ideas for crash. Only thing left is that maybe you have different hardware revisions of the device, but this is hihgly unlikely...
So, I would make a poll and see how many FC'ing MS323 users have either a revision C phone/updated to revision CI wondered the same! It's happened before but it makes no sense... I saw we make a test to see where in the world people have working/not MS323s
That too! How many had the phone come with revision C already on it. Like when they got it. Cause I got mine in the first DAY it was releasedSo, I would make a poll and see how many FC'ing MS323 users have either a revision C phone/updated to revision C
I had 3 MS323's, the first one came on version A, then it died, 2nd one came on version B, died too, current on version C. First two never had problems since I never came close to installing version C. This one did until I disabled the lockscreen and dirty flashed any CM based ROM.That too! How many had the phone come with revision C already on it. Like when they got it. Cause I got mine in the first DAY it was released
Mines came preloaded with 10B. I got it on Decemberish. Guess I got from the old stash of ms323s, my friend got preloaded 10c... he has no problems with ROMs... kinda surprising. Flashed CM12 today for him. Now THAT's news.That too! How many had the phone come with revision C already on it. Like when they got it. Cause I got mine in the first DAY it was released
(Most) devices can't open the files, I think that @vm03 @zlaja84 and you, should team up and build a kernel off the last stable build ever for ms323's then build bug fixes like camera off of that.What? Hmm, so it can't be possible, unless some devices can't open the keymaste(r) files for some reason.
Not a bad idea. I will try to look into it. But here is a hotfix for now:
It'll really help once VM03 gets his MS323 shipped to him, still waiting... can't wait for it to come to Mother RussiaNot a bad idea. I will try to look into it. But here is a hotfix for now:
1) Install version 2/19
2) Disable the lockscreen, and enable any settings that you want in the security menu.
3) Dirty flash any CM based ROM over it, and install GApps.
4) Download any secure lockscreen app on your phone.
Problem solved for now until the main lockscreen is fixed.
Compare between what? I promise it won't show anything unless you're comparing system filesHmk. I'll take a screenie of the back info of my MS323, let's see if we can compare.
Since you said there's different variants of the ms323, take a back screenie,of screenie behind the battery, blur out the semi and serial number if,needed.Compare between what? I promise it won't show anything unless you're comparing system files
It was just a theory. *shrug* I guess but I don't think that's the way to detect.Since you said there's different variants of the ms323, take a back screenie,of screenie behind the battery, blur out the semi and serial number if,needed.
Hey, you NEVER know what could happen. Important things might happen with the most simple things.It was just a theory. *shrug* I guess but I don't think that's the way to detect.
I know, I know. Even still. *shrug*Hey, you NEVER know what could happen. Important things might happen with the most simple things.
You're welcome to if you'd like, I'm not trying to discourage you.Compare between me and you:I know, I know. Even still. *shrug*You're welcome to if you'd like, I'm not trying to discourage you.
Mine says v10c, H/W is 1.0.Compare between me and you:
That's extremely odd and we have FC's, I wonder what @crutchcorn has, might tell my friend aswell what he has.Mine says v10c, H/W is 1.0.
