Root MS323 System UI FC FIX?
Actually guys, you know what? We've had this issue before with GPS and even key combos... Go flash the firmware A KDZ, then try out CM12. I'll bet you that does it
Darn, I pondered that problem may be in hw revision and I thought of asking you gusy that, but I guess you all have the same (1.0)....
I'll try to pull one from 10a stock. Maybe that helps since crutch has had this phone since 10a was out.
Nope it won't. we need patched aboot. I know which one is for d320👎 and d325, but IDK which aboot crutch uses. Let's hear what he has to say.
Copy it to SD and upload please
@xRaZeR_FuZioNx
1. Delete keymaste.* files on /firmware
2. Revert firmware(modem.img) and delete keymaster.* on /system/vendor/firmware/keymaster
3. Copy keymaste.* files from /firmware to /system/vendor/firmware/keymaster
4. Try to rename it, add "r" to end of name, befor dot.
5. Delete keymaste.* files on /firmware
6. Delete keymaster.* on /system/vendor/firmware/keymaster
Reboot and test after each item.
Anybody can try it?
