Help MSL code?
skarface1988
Have anyone goten there msl code on there vm victory?.
I try almost every method ive seen and no work =(
Please help.
Please help.
i did but you need Root and a catlog program
once rooted and catlog installed open catlog go to attempt you 33debug edit with one attempt made back out goto catlog and search it for msl
you should then see a line with the code all numerical.
Please help.
I went through troubleshooting wIth VM via email, and as part of the reprogramming instructions, they sent my MSL. So you cOuld always try a little social engineering to get your hands on it :-)
This is for Sprint Victory to be used on a different network.
Zeroing SPC on the Victory is quite painful. Open DFS demo and put 16 digit password. Phone will accept the password as "correct". Close DFS demo and open QPST. After zeroing item 85 in efs explorer, open QXDM and zero the SPC. Do not reboot after changing in EFS explorer, reboot only after completing QXDM.
At QXDM Command output do the following;
password 2012112120131219 - a message 'correct' should show
REQUESTNVITEMWRITE SEC_CODE 000000 - this will change your spc to 6 zeros
Reboot and enjoy
Please help.
Try this one :
1.Dial ##3282#
2.Enter random 6 digits number until its give an error sign
3.Now connect your Victory to Windows
4.Run adb shell command via Command prompt
5.Run this command :
getprop ril.MSL
6.Voila! You got your 6 digits MSL code
At least,it worked for me :)
The msl should be the same for all the victory's out there, mine was 595465. I just talked to the Virgin support staff over facebook and they gave it to me.
I can't speak for virgin mobile, but I know that with sprint they will release the MSL under certain conditions only. It has to be a phone that is not world use, meaning it can be used on another carrier overseas, the account has to be in good standing, not past due, and the line the phone is on must be out of contract (for people in a contract, obviously.) The most common use for the MSL that I have seen is manual programming if a phone swap was done and the phone will not work, nor will it go into hands free/one touch programming.
Sprint's far more liberal about giving out the msl. If one rep won't help, ask for another.
If that fails tell Sprint you're having trouble with streaming media and you want to be able to reset your phone on your own.
Yeah all I know is Virgin will ask for your number and your pin and they'll just give it out, provided you give them an actual reason.
Easy just put the phone on wifi and download(msl utility) but dont open it just dial from the phone ##3424# the phone ask for msl just type any number on it and go back to msl utility and read your msl...:d
