Help MTP Transfer issue
I am having issues with transferring music from nexus 7 to laptop. When I open the the tablet on the computer and go to the foldeR where my music is stored, not all the files are showing up. Only some of the artist are visible. IDK why the others arent there.
Any ideas of what to do to find them? I am running Vista on the laptop if that matters?
Any help is much appreciated.
What I'll tell you won't really help you, but they're where you put them. You'll have to figure out what the missing ones have in common and where you could have put them. (Or what you could have gotten them with - that app might have a location it stores music.)
Well I have Utorrent and have all the music going to one folder. They show up in the folder on my pad but when the computer opens the folder some don't appear. When others do....
Also I look at the torrent folder or download folders on the pad and there not anywhere else but the music folder. So its baffling me
Most likly its in different folder. Install ES Explorer and search for miaaing songs, then look at details and make sure they are in right place. You can alao transfer files very fast via wifi, no cables needed. or FTP server.
