Root MUIU Xj A2SD Doesn't Seem To Work Very Well
Mattb81
Hey guys,
I just tried MUIU xj for a few hours and while I like the novelty of an iPhone I found I ran out of internal memory (on stock hboot) after installing far fewer apps from titanium backup.
Anyone know why that would be? On a sense rom and oxygen I have much more space, although I have noticed even on oxygen I have less space with the same apps than on my original a2sd sense rom. It seems different roms use different amounts of my ext even though I am installing the same quantity of apps.
I found I had more space than when I used Redux, although as the stock apps are so good in MIUI I decided to keep some so have a few less apps.
Try flashing the a2sd file from recovery, I found that was the inly way I could get a2sd to work, after trying everything else including the app and the terminal commands.
Flashing the a2sd file worked a treat.
