multi tasking trouble
wallstreet123456
We just received a note 2 and must have done something wrong because we used to see a tab on the side of the screen that we could touch and it would slide out choices to pick from for opening multiple windows, that is no longer there.
Can someone please tell me how I can get that back?
Thank you
Thank you
Keep your finger on the 'back' (bottom right soft key) button then it will appear.
Thats if it's been enabled in your notification panel :)
You can also reposition the blue tab to the top, right or bottom of the screen. Just expand the tab, then press and hold the tab and drag it to the area of the screen you want. ;)
Then if you want to get rid of the tab just hold the back button again and it will vanish :)
Love the multi tasking on the note 2 and ive used it more than i thought i would
