monkeytools
Hey Casio lovers.
Are you looking to install recovery. But it seems too hard. Well I have made it easy for you. This will install recovery from there you can install su binary and superuser.apk. Then you will have root. It will also install my boot.img too, and you can reboot to recovery with one click of a button. All you need is my new OneClickTool and GNM recovery. I included the drivers for the phone, and the stock recovery + my boot.img.
Download recovery here:http://androidforums.com/getitnowmarketing/330813-all-in-one-recovery-thread.html
OneClick Recovery installer download here:Dev-Host - Multi tool OneClick Installer.zip - The Ultimate Free File Hosting / File Sharing Service
Now DO THIS AT YOUR OWN RISK!!!!!
You must have usb drivers installed.
You need to enable bypass booting here is the instructionsOriginally Posted by*Techniq*In the Program Menu (##PROGRAM aka ##7764726, pass 000000) Enable it and save and reboot phone.
How to use OneClick Installer
1. Download recovery
2. Download OneClick Installer
Make a folder on your desktop. Name it what ever you want. Put OneClick zip in the folder you made and unzip it.
3. Install the drivers if you dont have them installed all ready.
4. Place recovery in folder. That you made. Rename recovery-ra-commando-3.06-gnm to recovery. Plug phone in and make sure usb debugging is on. Double click on Multi Tool OneClick Installer. And make your selection, and hit enter. It will do the rest.
NOTE: Do not have both stock recovery and Gnm recovery. In the folder where the oneclick tool is at the same time. There is a keep folder for stock recovery. Just make a folder for GNM recovery and put it in there. If you want to flash stock recovery. Just pull stock recovery from Stock recovery folder, and put it in the folder you made with the multi oneclick tool.
If this help you hit the thanks button. ENJOY
Thank to rasta4rest for his root guide. that guide gave me the idea to make this tool. link to his guide here:http://androidforums.com/commando-a...loader-install-gnm-recovery-via-fastboot.html
Thank getitnowmarketing for his recovery. With out it we would not have this tool. already link to his page earler.
If you would like to help make this tool better. Then pm me and we will talk. This is a work in progress. Will update when time allows. If you edit this tool and brick your phone I am not responsable. You do it at your own risk. Thanks
