Multi-Window on Verizon Note 2?
Droid Ninja
Will multi-window be available out of the box on the Verizon Note 2?
And how will it work? Like, can I browse a website and have the youtube app open all on the screen all at the same time?
Yes, it already has it. Verified it myself last night.
Yes, it lets you have 2 apps open at the same time. The app selection is very limited right now, it seemed to have less than the videos I've seen.
Oh so it limits you as to which 2 apps it lets you have open at the same time? That sucks. My dream combo is Chrome/youtube.
Maybe they will expand the allowed apps or there is a way around it?
I have a rooted AT&T Galaxy Note 2 running the Saurom ROM and I can use Chrome and YouTube at the same time. It comes with a MultiWindow Control which allows you to add any apps you want to the multi task bar.
Chrome and YouTube should be two of the apps already in the multiwindow list. It was on mine, though I have the international model.
Ya, sorry, I can't remember which ones where on the list (too excited to be playing with it).
I'm sure they'll add more & like hack3rman said - you can add anything to it once rooted.
I haven't checked on this since getting the att note 2, but am I understanding this correctly:
Sprint note 2: update released so can do multiscreen.
Att: disabled at release. Not enabled yet.
Verizon: enabled on release, but limited apps available for multiscreening.
Tmobile: like sprint, was disabled at release but update released so can now do multiscreen.
Correct- that matches my status report Nov 29 2012
I was fairly shocked when I walked into VZW today and played with the SGN2. Multi windows??? I thought only Sprint had that States-side. I immediately bought it! VZW tramp stamp and all.
I was hoping teh same was true of screen recording but I can't seem to activate it so I'm assuming that's a no go so far.
It has multiview, but it is currently limited to the default apps in the bar and some apps in the play store that support it.
I see what you're saying, I just tried to add Chrome and I can't. Boooo.
Do the global versions allow you to add any apps to it vs ours?
Yes, the international version can. I think Sprint just received multiview, they may be able to do it also.
I think the Verizon version will get that ability in an update.
US Cellular doesnt have multiview for the Note2 yet except for things that are never used like the phones own video player or Snote.
There is not a single app that I am interested in using in the Verizon or Sprint versions of Note II MultiWindow or in the Play Store. So for me MultiWindow is currently a totally useless feature that I have disabled in Settings/Display ;)
There is a thread on xda that has links to several apps that have been modified for multiview.
Netflix, chrome, and several others are provided.
http://forum.xda-developers.com/showthread.php?t=2024399
