BigPeanutHead
Member
Not good...
"If your international Samsung Galaxy note 2 comes with version N7100XXALIE, you will come to the disappointing fact that the multi-window feature is unavailable. On the other hand, if you are running firmware version N7100XXALIH, as many people are, the feature should be working as you would expect. You can check out what firmware version you are running by heading to Settings and then
