Root multiple calendars not syncing
D
Deleted member 494604
Guest
I was getting a force close every time calender sync'ed, so I cleared all the calendar data from the phone. Now, under Settings | Calendars, only "My Calendar" and my main Google calendar appear. I'm missing my secondary calendar and my husband's (read-only) shared calendar. I've tried forcing a sync multiple times and have rebooted. Any suggestions?
Thanks,
--Charlene
Update: Since my secondary calendar didn't have much data, I deleted it then re-added. It now shows up in my list of calendars. I unsubscribed form my husband's calendar and re-added it. It's still missing from the phone.
This was happening to some people when we flashed to EC05, if I remember correctly you just need to wipe the data in the calendar and let it re-sync. Let me see if I can find it for you.
Found it:
"Go to settings>applications>manage applications>select the "all" tab on top>select "calendar storage", then select "clear data". You phone will re-sync and all will be good again."
I had already wiped the data once. Decided "what the heck" and tried it again. This time it worked.
Thanks,
--Charlene
