multiple launchers
I've finally gotten around to checking out other launchers...I've installed Launcher Pro, Go Launcher, and ADW Launcher. Is there any issue with running these at the same time or should I only have one installed at a time to really evaluate it. I'm looking at lags and responses, so I don't want to skew that by having more than one installed if it makes a difference...
I've got four in mine.
It'll ask for a default launcher choice on boot, unless you've already selected that on prompt and indicated so in the checkbox.
Including stock, I've got 3. I'm using Go Launcher as "personal", and LauncherPro as "work." I might eventually set up a 3rd(4th) as "public", if I can find one where I can lock down some abilities and access.
Only issue I've come across is a bit of lag or loading time when you first switch to a launcher as it cashes and RAMs up. ex.widgets need to reload, app drawer needs to fill in.
Also if you don't pick a default, every time you press the "home" soft-key it will prompt for launchers.
