Help Multiple problems, immediately can't op-en Contacts
DragonDon
So slowly, but surely my Galaxy Tab has been degenerating in it's overall duty. Nothing seems to help it. I am quite convinced that this all started after the first Kies update it received shortly after I bought it earlier this year.
Let's just try to takle things one at a time, they may be related or may not.
First, and more critically, I can't open my contacts. When I do I get the error message "The process andrdoid.process.acore has stopped unexpectedly. Please try again."
This started happening yesterday when the device randomly shutdown on it's own (has been doing this for a while now) and when I turned it back on, this problem happened.
First I tried wiping just the cache portion (did it 3 times before rebooting into normal mode). Did not change anything.
So then I resigned myself to a factory wipe(did that 3 times before rebooting into normal mode). I really hated to do this but I NEED my contacts for my work. After the wipe and a sync, the contacts opened. Yay! So I finished re-installing all my apps again and now it's gone right back to doing the same thing with same error message.
As far as I know, none of the apps installed have anything to do with contacts or address book.
I will be making a visit to the Samsung service center near me but if there is something I can fix over the weekend with the fine help of the community here, I'd feel much happier.
So here comes the tech stuff.
Model SHW-M180S (I bought this in South Korea and am currently living there)
Firmware - 2.3.4
Baseband - M180S.EH12.1526.ST
Kernel - 2.6.35.7 se.infra@SEI-45 #2
Build# - Gingerbread.TH12
If you need any logs, just let me know exactly what to gram. I have System Tuner installed (seems to be pretty good at grabbing logs) and this is a completely non-rooted device(if that wasn't obvious already...).
Am having the same problem on my Galaxy Tab. Contacts keep multiplying from the calls I have made and crashes the contacts so that I cannot open them. Have read a few ideas on the forums but still cannot work out how to fix it. Any ideas or pointers so far?
Cheers,
Seb
