I have several issues with my RAZR m (first day using it), and I'm hoping someone can help. Between the new version of Android (4.04), and the way this phone works, I'm flummoxed.
- no apps seem to be able to browse the sd card at all! For example, my ebook reader (aldiko) can't browse to my sd to import new books - it only sees the 8GB internal memory. Same for many other apps including the file browsers. Basically my sd is useless for anything outside saving pictures and video from the camera. Is there any fix for this?
- I can sync my contacts with Facebook, but only the data syncs, none of the avatar pictures sync at all. When I try to add them manually, there is only the option to take a picture or select a saved one.
- the led light doesn't seem to come on when I plug in to charge. Where are these options?
I'm sure there's more, but these are the worst offenders. Any help is appreciated...
