Help Multitouch Issues
rs98
Dec 19, 2012
220
15
CT
I've been having a weird multitouch problem lately. I used a tester which told me that the Evo V has four multitouch points, but often, it gets messed up with two or more touches. When playing games, the second touch seems to get inputted, and it starts acting randomly. As odd as this is, it seems to be a problem with the lock screen. When I had Go Locker, this problem started. When I reset the phone, it went away but came back shortly. The same happened with Widgets Locker, so I ended up uninstalling both. If anyone else had this problem, how can I fix it?
Thanks
messing with the lockscreen causes multi touch issues. I use No Lock, which completely disables the lockscreen. It causes multi touch issues, so when i need consistent two finger input (i.e games), i'll disable No Lock. If i only occasionally need a pinch to zoom, i can still keep No Lock enabled. It'll start messing up if i try to do a bunch of 2 finger gestures continuously.
edit: i haven't found a fix, but I can deal with it once i know how it's messing up.
Upvote 0
BEST TECH IN 2023
Smartphones
