Help music not in correct order... auto alphabetized always
make sure you have track numbers in the tags. If there are no track numbers, then almost all music players will alphabetize the tracks.
Same happened to me when I used Windows Media Player to transfer mp3s to the DX. I deleted all the music from the SD card and started over by manually copying files over and that worked.
Hey guys, the easiest way to put music in order is to create a play list , press on the album, then add to the play list. Worked for me. Good luck :-)
