To transfer the music from your comp to your micro SD card, you will need an adapter that allows the card to be inserted into your card reader.
Alternatively, put the music onto your tab,then move it to the card. You will need a file explorer for this. Astro is a good free one,ans is found in the market.
Try another music player. If you read reviews on other players you will find what your looking for. Im playing all my movies from my sd card. And I think I played my music before I switched stuff around but Im not sure.
Thanks. Do you know of any in particular that work well and can use the SD card?
