Root Music Player help
Alright so i have the TWRP installed so i install this how so?
Edit: Can someone upload the JmzStock_VM_Shooter_Deodex.zip to another site, because form goo.com my download keeps losing it speed until it gets to 2 k/bs
I would but it would take me like, an hour to download and then upload to my dropbox, and I have work in the morning
so i flashed the beats audio file and now my music player force quits every time but every 3rd party music player works fine. Any way to fix this?
Here is the link for the file i flashed: [MOD][5-18-12]Beats-Flashable-Sense 3.0+-Evo3D-Updated for ICS !! - xda-developers
not to sound condescending at all but that says it is for Sense 3.0. these phones are running sense 3.6. Hugely different framework. thats why you are having issues with it. flashing a diff rom will fix it. I know goo had some issues today but is reporting everything is good now. try the download again
1. i flashed your ROM and wanted to know if beats was included.
2. I flashed the ics one as it says 3.0+
I just flashed it on my Rom, wiped data on HTC music and HTC music enhancer and having no issues whatsoever with it. So go ahead and try again since you are running my Rom now. Be sure to wipe the two above before you try to play music
I will do it later, im just happy i got music working again and lee droid tweaks
I had the same problem when I was on the stock + SU rom from the stickied root guide. I have since flashed Jmz's deodexed stock rom, and tried adding beats again and now it works great. I then read thru the beats thread on xda and saw the same thing, the dev says it will only work on deodexed roms.
