Help Music Player Question
cgobyd
Ok, I have several edited songs/sounds that I use as ringtones, and alarms, that are mp3/4 all downloaded from Zedge, and I was wondering if there was anyway to either remove these from the Music Player's List or indicate that they should not be played without deleting them.
Because while I like these ringtones I am getting tired of having my alarm being played while I'm trying to listen to my music.
I think some players allow you to change your music to a ringtone/notification (i.e. Doubletwist). After that, you can probably delete the song from your playlist.
OR you can go to your file system, locate your songs in the \Music folder.
From there, long press on the song & Move the file to \media\audio and either move the song to your \ringtone folder or your \notifications folder.
