Kamala
Member
Title says everything. I made this thread to help newcomers with basic stuff.
Apps Installer - Enables install from SD card (you can download app with your comp and put it on SD card)
Quick System Info Pro - Imo the best task manager/monitor for Galaxy, has everything that we need. Second choice for OS Monitor
BateryTime Lite - Precise and lite app that monitors your batery status, can be used as widget but Im not using it due to low available memory in Galaxy.
ES File Explorer - Really good file manager (manages your files in phone and memory), also would recommend OI File Manager (lite but with less settings)
WiFi Buddy - I find default WiFi search very annoying, this will help you if you think like me.
Dropbox - Shares files with your computer
Msn Talk - Msn Client
Fring - Was the best VOIP client, sadly not working for Skype anymore so we are waiting for Skype VOIP app that actualy works.
Skyfire - Browser that supports flash.
Zedge - Huge collection of wallpapers and ringtones
Digiclock - Only widget that Im using atm, only cause it has date and day with not much usage of memory.
i7500l. It says cannot find on market and when i d/l the apk it says it can't unpack.
