Hey guys - see if you can help with these two issues?
1) After I make a call, the screen goes black in a matter of seconds. I'm typically using a headset when I notice this. To end the call (or enter numbers in a call menu) I need to press the sleep button to get the screen to light up again. This is a pain in the a$$.
I have the screen timeout set for 2 mins.
2) About once or twice a day the home screen will lock where I can't press anything. I need to reboot to fix.
About my phone:
-Build #2
-Everything else works perfect
-Everything turned off...4G, WiFi...etc.
About my phone:
-Build #2
Sorry you are having these issues, and I do see that you posted your problem over in the Nexus 1 forums...keep an eye on that post as the folks over there might have more insight on that issue as I am unfamiliar with that phone.
