My android system is fail, because of systemUI.apk
keith Q
My phone is Atrix2(MB865) and the brand is motorola. The android system is 2.3.6
I tried to change the notification column of system, so people who made a apk in the website. its name is systemUI.apk .I was downloaded it and copy it to system/app. And then system was noted me the system got trouble and I can't close it. I had no idea,so I was forced shutdown it and then restarted. But when I restarted it , the notification columm was disappear.
So that, I think the apk is improper my phone.
I think if people who can copy correct systemUI.apk and systemUI.ordex to me ,I can solve this trouble.
The version of phone is Atrix2 AT&t mobile U.S.
If someone use this phone,please send it to me.Thank you.!
If you have,please contact me via PM so I can send you my email so you can send it (the apk) to me. thank you!
keith Q,
I removed your direct email address and changed the wording so that if anyone has the .apk file you need, you can send them your email address privately via our PM (personal message) system.
This should help keep your email information private.
Cheers and best of luck getting your issues fixed (and welcome to the AndroidForums! :)).
i have a motorola milestone 3, and that happened to me the same, but i already solved. if you still need help send me a PM
