Help My Apps not showing in Android Market
drive88mph
This is a very common error nowadays and i cannot fix it!
Im on Ressurrection Rom 7.4 with ICS and whenever i choose "my apps" in the android market, i get the message saying about my downloaded apps showing up there but none of them appeared
i already tried the titanium market doctor solutions, the delete market file with root explorer and deleted the cache from manage applications with no luck
what else can i try?
Did you ever find a solution?
I'm in the same boat as you. been trying for past couple days. going back and forth re-installing the ROM, countless data wipes, dalvic wipes, cache wipes to no availability.
I made a new account and apps that install shows up on my apps but not my main account
If I do a data wipe then go to market then my apps. first time going in, my purchases are there. but if I exit and go back. they are gone again.
My library on andorid market shows all apps I have downloaded and installed. but its not syncing to my phone the data
If you have titanium backup installed try using that to attach the apps to the market.
Edit: must be going blind, that's already been suggested.
