Here is my first attempt along with my first post. I purchased the case/holster combo from Verizon store when I bought the phone, and trimmed SLOWLY with Dremel and Exacto knife. I had an old Invisible Shield lying around which I used to cover as much of the battery as possible. My only concern is the thin piece I left above the volume button. I though by leaving it there the case would have a little more support, but if I remove it the case will fit slightly better. It will work for me until there is something available that look/works better.
On another note, what is the round hole/ rubber thing below the kickstand?
https://picasaweb.google.com/111788101074169706103/Apr32011#
I can't figure out how to post pics, sorry.
