My battery consumption. What you guys think.???
Well this is after a full charge. Using nova launcher, wifi tethering my ps3 a few hrs. Using like I always would. Then leaving it on/unused for 7hrs while I sept
What u guys think
Do you use your gallery that much? I noticed mine was eating my battery and found out somewhere that it was trying to sync with picasa, but couldn't. I disabled it and it seems to be working better now.
So I always wondered if it was bad to leave your phone on the charger after its fully charged and play pandora, internet etc.
Well I was doing just that and noticed that the phone was hottt. So I pulled it off and continued to play pandora, tether my ps3 and surf tapatalk.. before I know it I see the gsam battery monitor tell me my phone is at 107 degrees. Immediately took off the battery and let it sit off for a half hour. So I'm guess it could fry your battery/phone if you leave it on and do too many things.
Also noticed that the gsam wont calculate how long my battery will last. Maybe its faulty and needs a reinstall I dunno
Here is yesterdays and last nights drainage
Hows it look
This is my first 10% also switched my mobile network setting from lte to gsm only. Should I keep it that way or use WCDMA?
Here is my first ten percent this morning since off the carger. Haven't tethered my ps3 yet. And just stepped onto tapatalk. This is after switching my mobile networks to WCDMA ONLY.
When phone was on gsm only it was terribly slow and didn't seem to save any battery.
Check this out.
47m of screen. On time.
Whats going on with this phone. I tethered my ps3 for about a hr
