I have had my Android 10.1" Jellybean 4.2.2 for about 3 weeks now..
Hi There you friendly clever people,
When I 1st Paired my new Bluetooth Keyboard it worked fine.
But of course when I powered off It had to be paired again.
So the next time I just made the android go into Sleep mode & when it powered up again the Bluetooth keyboard was still working ok,
(I also left the Bluetooth keyboard on)..
But the next day I powered off the android, When I switched on again the keyboard was not working again.
But When I tried to pair the Keyboard it found it ok but when I pressed the Bluetooth Keyboard Button the code number came up for about 2 seconds.!!!!
So I did not have time to input the code number,
(As you have to input the code while it is displayed on the screen).
When I first installed it the code stayed on the screen until I pressed the Return/Enter Button..
I have even pressed the reset hole button using a toothpick, But it is still the same,
The Code for the Bluetooth Keyboard still pops up and goes away so quickly that I do not time to input the code number.
So do any of you clever people on Phandroid know how I can make the code number stay on the screen long enough for me to input the code number.
This problem is really driving me Mad..!!!!!
Also once it is installed why does it not work after I have powered down & then Restarted the Android.
Is there anyway that it will still work after I have powered up the Android..!!!
Man Thanks Friends Dave Gould..
Many Thanks Dave Gould..
