My Contact Card - possible to merge?
So my desire has a 'My Contact Card', and my contacts (gmail contacts synced to phone) also has my gmail contact with all my info.
Is it possible to merge these? I cant find a way. Seems silly for the gmail personal contact to be on the phone and for the phone to hold a seperate one (used when i send texts etc?).
Any ideas?
Thanks
I think the idea is that the "My Contact Card" holds the minimum amount of information that you'd want to Share (by Bluetooth, for instance") with someone else that, say, you've just met. You wouldn't want them knowing your address or other information you might keep in your main contact entry, would you?
