defaults to Hancent SMS App, a box where you can type a message pops up instead of the camera app....
HELP?
Can I fix this without uninstalling Handcent App?
Thanks in advance
drexappeal;[URL="tel:4281982" said:4281982[/URL]]There must be a setting on an app you have installed that is forcing the camera button to launch handcent instead of the camera. I'd check though all the apps you have that can re-purpose the hard buttons for different functions. There's gotta be a way to change the setting to the default funtion.
+1 I just loaded up HANDCENT SMS & cannot duplicate the camera button issue that you're experiencing.
I'd suggest booting into SAFEMODE & then re-load HANDCENT SMS to troubleshoot/eliminate HANDCENT SMS as the possible culprit.
If the problem persists,I'd contact the developer ofthe HANDCENT SMS app.
Thing is, I don't even know if it's handcent. Does handcent have any settings where you can have a different button launch the app?
I think it may be a different app, where there is an option to dedicate a button to launch a different app.
I know that widget locker has some settings like that, where you can have one of the hard buttons re-purposed to open an app. There are a few other apps I know can do something similar as well.
