Root My droid bionic won't root
I need help rooting my Droid bionic 905 2.3.4, i have tried everything that i know of. here are the problems I have run into.
PETE​
Have you tried Razrs Edge? Ive used it a few times after FXZ to 905. Hit the link below and give it a shot.
Razrs Edge for Windows
Click File in the upper left, then Download. Just to clarify because google docs can be a bit confusing with the way its set up...
Razors edge should have worked same with motofail. AHow do you know it did not work? is there an app call super user on your phone?
and tried motofail-GB which sent my antivirus crazy saying it was a trojan ( incidentally my wife's email was hacked at the same time as I was trying to use this ...coincidence?)
I also tried Razrs and got nothing. but this
[*] Motorola Razr ICS Root Exploit (Windows version)
[*] by Dan Rosenberg (@djrbliss)
[*] Before continuing, ensure USB debugging is enabled, that you
[*] have the latest Motorola drivers installed, and that your phone
[*] is connected via USB.
[*] Press enter to root your phone...
Press any key to continue . . .
[*] Waiting for device...
[*] Device found.
[*] Rebooting device...
[*] Waiting for device to reboot...
rm failed for /data/local.prop, Permission denied
cannot create /data/local.prop: permission denied
[*] Rebooting device again...
[*] Attemping persistence...
remount failed: Operation not permitted
failed to copy 'su' to '/system/bin/su': Read-only file system
Unable to chmod /system/bin/su: No such file or directory
failed to copy 'busybox' to '/system/xbin/busybox': Read-only file system
Unable to chmod /system/xbin/busybox: No such file or directory
/system/xbin/busybox: not found
failed to copy 'Superuser.apk' to '/system/app/Superuser.apk': Read-only file sy
stem
[*] Cleaning up...
Unable to chmod /data: Operation not permitted
[*] Rebooting...
so what else can I do ? I tried to DL the whole zip file but had to DL them separately I then put them into the same file folder.
could that be the problem? is there another place to DL the zip file as a whole?
really want to get root back! I hate all the damn bloatware!
thanks in advance,
Scott
1) Superuser is installed
2) Rootchecker says that I have root access
3) Root features on any app that has root features DO NOT work. Even if SU grants them permission.
Updating SU binaries succeeds but upon checking itself to see if new binaries work, it says "failed". I am getting the same errors within moto-fail as the OP.
