Kirch21
To fix your SetCPU problem, don't select 'Droid' as your device, just choose auto detect. That will let you adjust the sliders without screwing it up.
As for running at a higher frequency, you need to download either the boot image or a nandroid backup of the boot image that allows you to run at the higher speeds. Then SetCPU will detect these new frequencies and allow you to use them.
You can find those images at the same place you found the bugless beast ROM.
Ok thanks! Do you know if there is a bugless beast cloaked to 1.1?
Just checked the "BatteryLife" widget, my current battery temp is a SMOLDERING 82.4 degrees. Crazy, right? *yawn*
