My phone will not come up in the Fastboot devices list
the responce goes as followed:
the device is rooted, i have reflashed the stock firmware, and re-rooted after running LG Laf Recovery Multitool v1.2 and it soft bricking my phone, but i am still stuck, using abd devices comes up with the phone, but fastboot devices does not recognize it, i cannot get into fastboot, as download mode is on, and i cannot unlock the bootloader, even using the bootloader unlock from the forum...
please help!!
I am using windows 7 Ultimate x64 by the way
Edit:
after installing the full sdk, still nothing
if you could please help, it would be much appreciated!
and i do have fastboot installed:C:\Users\sever\Desktop\bootloader_unlock_part1>fastboot devices
i am going to try a different way of installing adb and fastboot and repost:\Users\sever\Desktop\bootloader_unlock_part1>fastboo
sage: fastboot [ <option> ] <command>
ommands:
update <filename> reflash dev
flashall flash boot
flash <partition> [ <filename> ] write a fil
erase <partition> erase a fla
format <partition> format a fl
getvar <variable> display a b
boot <kernel> [ <ramdisk> ] download an
flash:raw boot <kernel> [ <ramdisk> ] create boot
devices list all co
continue continue wi
reboot reboot devi
reboot-bootloader reboot devi
help show this h
ptions:
-w erase userd
if supporte
-u do not firs
formatting
-s <specific device> specify dev
or path to
-l with "devic
-p <product> specify pro
-c <cmdline> override ke
-i <vendor id> specify a c
-b <base_addr> specify a c
default: 0x10000000
-n <page size> specify the
048
-S <size>[K|M|G] automatical
n
size. 0 to
please help!!
Edit:
