I'm not usually one for asking for help but I've done a lot of googling and forum searching but couldn't find a definate answer so here goes.
My problems started a few days ago when I installed GV.The installation went OK,it was only afterwards that things started going wrong.The phone would forget settings,was constantly having to import numbers from the sim card etc etc.I decided to go back to Leedroid but first I gained S-Off with the use of Alpha Rev.I probably did a stupid thing installing AR hboot cause it just seemed to want to reboot after every new app install.
Anyway while trying to install Leedroid I got stuck in a boot loop,tried to go back to GV via backup in recovery and all my data was gone.Went looking for my backup sd and that's gone missing aswell so now if I try to install a new rom (doesn't matter what type) I cant get past the AR boot screen.
Is AR the problem or is it something more serious ?
Thanks Vinny
Thanks Vinny
