my flashlight method w/o root
Kg198202
My brother and I have found a way to use the flashlight w/o root on the warp. Im not sure how long it will stay on or how long it should stay on because ive only used it for a minute or so before cutting it off.
To use a flashlight : we have our camera flash set on, once we click the shutter button and its in the middle of taking a pic we hit the home button before the picture is taken. Once youre on the home screen the light will remain on until you go back in the stock camera app and finish taking the picture.
If you would like to use the flashlight for the camcorder you complete all the above steps but once youre back in the stock camera app and you slide the button at the bottom to the camcorder thingee at the bottom.
ive only used this method a few times so im not sure as to the ramifications to your warp if thier are any...
I just tested and it actually works... I wonder if this would work on other phones...
Sent from my N860 using Tapatalk 2 Beta-5
This works. Somehow I would guess this is unique to the Warp because it's the friggin' Warp, and whoever made it is special.
The flash remains on when I return to the Camera app, and only after do I snap another picture (flash-on) does it disappear. Didn't try recording video or things without the flash.
:D
lmao....youre right they have got to be special....
