My Hero Restarting
I use to have the Samsung Moment and used Advanced Task Killer and everything worked fine. When I switched to the Hero, ATK would restart my phone (HTC logo appears and then all apps say loading). I switched to Task Killer. It worked great until i turned off my phone. When i turned it back on, and used Task Killer, it started restarting my phone too. WHY IS THIS HAPPENING?! ITS SO FRUSTRATING!:mad::mad:
You're probably killing the SENSE application.
I'd recommend not using a Task Killer. Stopped using one a few weeks ago and the phone runs much better, as does the battery.
Yea, I had task killer on mine screwed it up something fierce now I have a new one be sent to me cause sense force closes & a host of other problems. Been told removing task killer and a hard reset should help idk try it
